Sharing cookie between httpand https
Hi, Wanted to check how to create vip where if users while browsing switches from httpto https or vice versa then cookie should remain same. Can I use the same cookie profile for httpand https,will this work? Or do I need to use universal cookie and both should use same universal cookie?
Please suggest.
- nitass
Employee
is it same pool? if yes, i think default cookie persistence profile should work.
otherwise, you may use universal persistence with match across option.
sol5837: Match Across options for session persistence
https://support.f5.com/kb/en-us/solutions/public/5000/800/sol5837
