SharePoint iApp / WAM must be provisioned when a Virtual Server is using a Web Acceleration profile
Am in the process of setting up separate iApp to test the functionality of WAM and SharePoint and getting this error when I try to deploy the iApp.
01070668:3: WAM must be provisioned when a Virtual Server is using a Web Acceleration profile (/Common/Sharepoint_Test_2010.app/Sharepoint_Test_2010_optimized-acceleration) with attached applications.
AAM is already provisioned as Nominal, so I am not understanding why I am getting this error.
- cdomansky
After several weeks of troubleshooting with F5 support, it appears the issue with AAM licensing is related to datastor config object that effectively disabled AAM on load.
sys datastor { web-cache-weight 0 }
To resolve the issue, run this command:
tmsh modify sys datastor web-cache-weight 50 tmsh save sys config partitions all
