Setup High Speed Logging on Client Auth iRule
I have the below iRule and I would like to add high speed logging functionality instead of logging to the local0 LTM file. We have a splunk server where we stand all of our logs from the F5 when then come from an iRule setup with HSL. So basically, everywhere I have a log local0 command, I would rather send those logs to Splunk using HSL. Thoughts?
when CLIENTSSL_CLIENTCERT { if { [SSL::cert count] == 0 } { log local0. "No Certificate Provided" drop } else { log local0. "Client Certificate Recieved - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" if { [class match [X509::serial_number [SSL::cert 0]] equals ValidCertificates] } { log local0. "Client Accepted - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" } else { log local0. "Client Rejected -IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" reject } } }
Something like this? Make sure you setup the syslog pool (hsl_syslog_pool).
when RULE_INIT { High speed logging setup - local7.info set static::bigip [info hostname] set static::facility <190> set static::hsl_prefix "$static::facility|host=$static::bigip" } when CLIENT_ACCEPTED { Open a connection for high speed logging to hsl_syslog_pool & define log prefix set hsl [HSL::open -proto UDP -pool hsl_syslog_pool] set hsl_prefix "${static::hsl_prefix}|client=[IP::client_addr]:[TCP::client_port]" } when CLIENTSSL_CLIENTCERT { if { [SSL::cert count] == 0 } { set log_message "No Certificate Provided" HSL::send $hsl "$hsl_prefix|$log_message" drop } else { set log_message "Client Certificate Recieved - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" HSL::send $hsl "$hsl_prefix|$log_message" if { [class match [X509::serial_number [SSL::cert 0]] equals ValidCertificates] } { set log_message "Client Accepted - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" HSL::send $hsl "$hsl_prefix|$log_message" } else { set log_message "Client Rejected -IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]" HSL::send $hsl "$hsl_prefix|$log_message" reject } } }
