2funky_105078
Cirrus
Jun 18, 2013setting "forced offline" status for pool member
Hello,
We are coding a script in our servers in order to POST a url in order to put a pool member in FORCED OFFLINE which requires 2 calls.
The POST to do simple DISABLED works, but it doesnt work for the FORCED OFFLINE.as it gives HTTP 500 error.
This is what was told us to do in order to achieve it,
Is this correct? Why do we get HTTP 500?
The 2 requests for up/force offline
- Samir_Jha_52506
Noctilucent
try this. $state=array_fill(0, sizeof($nodes), 'SESSION_STATUS_ENABLED'); Or $state=array_fill(0, sizeof($nodes), 'MONITOR_STATUS_UP');
