Jordi_Feu_32626
Sep 01, 2010Setting Brute Force Attack for OWA 2003
I am quite new in ASM and even in OWA. Does anybody know how to set up Brute Force Attack for OWA 2003? I tried several times to configure it but it has no effects.
I tried as Login URL:
/exchweb/*
/exchange/
I tried HTML Form and NTLM as Authentication Type but no luck.
I would appreciate any help.
Thanks in advanced.
- Ben_Cuthbert_90Historic F5 AccountHi Jordi
What have you setup in the protection settings, is the operation mode set to transparent or blocking?
Have you added access validation strings?
And how are you then testing it? Do you have a traffic generator to test it? - Ben_Cuthbert_90Historic F5 AccountAlso chapter 7 of the configuration guide has a good step by step for brute force protection if you dont have it, it's on ask.f5.com
