Habib_Ulla_Khan's avatar
Habib_Ulla_Khan
Jun 20, 2017
Service is not responding when using POST .
Hi Devcentral mates,
I have a LTM VIP and the same server running some service. The url is https://renzenapp.abc.com/RezenServices/AccessControl.svc, when POST is sent using postman, getting below error.
415 cannot process the message because the content type 'text/plain;charset=UTF-8' was not the expected type 'test/xml;charset=utf-8'
Solution tried:
Changing content-type, not working.
Need help in fixing this.
  • Hi,
    If you get 4XX error that means something in your request is not OK. Did you tried to change the content type?
    If you show me your POST strig or the command that you use I can give you more information.
    Regards
