Serial failover between VIPRION chassis
"sol12326: Serial failover is not currently supported between VIPRION chassis" says this issue applies to versions of v11.3.0 and below. But the article hasn't been updated since 12/19/2012.
Can anybody confirm this issue has been resolved in v11.5.1?
- Daniel_Epperson
Employee
This has not changed and is likely to stay that way. We are in the process of updating the affected versions in the article. This configuration is a challenge due to the clustered nature of the chassis; network failover is instead recommended.
If this is a feature that you are needing, please open a support case so that we can log your interest.
