Send data of certificate over an head http with an iRule
Please i want to know how can i send the data of certificate over an http headre with an iRule.
- Kevin_Stewart
Employee
The easiest would probably be something like this:
HTTP::header replace CLIENTCERT [X509::subject [SSL::cert 0]]This would send the certificate subject in the CLIENTCERT header. If you wanted to send the entire certificate, you'd want to base64/URI-encode it first for transit:
HTTP::header replace CLIENTCERT [URI::encode [b64encode [X509::whole [SSL::cert 0]]]]You can also send the raw DER-encoded certificate, but you definitely need to base64/URI-encode it first:
HTTP::header replace CLIENTCERT [URI::encode [b64encode [SSL::cert 0]]]I'm not sure when, but I believe prior to some version of 11, the SSL::cert value didn't persist across TCP sessions. If you notice that the header is blank, that'll be why. You'll alternatively need to store the SSL cert data in the session table and call it up on each HTTP request.
- jlekt_135663
the version that i use is BIP IP 10.2.4. i'm new in this language (TCL). i'm going to try and tell the result after that. in fact i want to authenticate to an application, for that big ip should send the certificate to apache, and apache send the attribute to tomcat using AJP.
- Kevin_Stewart
Employee
I'm not 100% sure when the functionality changed, but please start with this:
when HTTP_REQUEST { HTTP::header replace CLIENTCERT [X509::subject [SSL::cert 0]] }This will send the certificate subject name in the CLIENTCERT header (an arbitrary name) to the server on each HTTP request. Make sure that the client SSL profile specifies request or require client certificate authentication, and that the Trusted Certificate Authorities option contains a certifying authority certificate (or bundle of CA certificates) that can validate the client's certificate.
Your Apache server should then be configured to look for this HTTP header in requests. Also notice that I used the HTTP::header replace command instead of HTTP::header insert. If you're going to be using the client certificate for authentication through an HTTP header, you want to make sure that the client cannot inject its own value. The replace function will overwrite anything that the client may send in the request.
