bjennis_8288
Mar 08, 2011Send button not working in OWA 2010 when using Firefox
When making a new e-mail in OWA 2010 webapp the Send button doesn't work.
The OWA 2010 page is distributed trough the F5 reversed proxy.
This is only when using a Firefox browser. An Internet Explorer browser doesn't has these problems.
The F5 does something with the pop-up "new mail" page that makes it corrupt.
Any ideas?
thanks!
Bart
- hoolio
Hi Bart,
Can you use a browser plugin like HttpFox or Fiddler2 to check the HTTP headers and payload in requests/responses? You can compare a working trace direct to a server with a failing trace through LTM.
Aaron - Mike_61719
Cirrus
Posted By bjennis on 03/08/2011 06:26 AM
Any ideas?
thanks!
Bart
Through an Edge Gateway or Firepass? - bjennis_8288
This is with the Firepass 1200.
@hoolio I'll do a trace and post te results. - Mike_61719
Cirrus
What version of Firepass and hotfix level? Are you using the new (firemonkey) proxy engine? - Scott_Carlson
Employee
Greetings,
This issue was reported in a support incident by another customer and we have identified the issue.
Since they mentioned this post, I wanted to include the resolution here in devcentral so you will have a fix. If you experience something like this in the future, please don't hesitate to open a support incident with us.
The problem was introduced by Exchange 2010 rollup 2. It didn't occur prior to installation of that.
Here's how to correct it until it's fixed in a cumulative hotfix.
Navigate to Portal Access>Content Processing and you will be under the heading "Preprocessing scripts".
Under "Web Applications Content Processing Scripts, click on "add new favorite".
Then put in the following
Preprocessing Script name: OWA2010_FirefoxFix
URL: match patterns: */uglobal.js*
Content Type: (leave blank)
Allow caching: Check this box
Sed processing script: s@!(a\.tagName&&a\.tagName\.toLowerCase()=="body")&&\(b\.setStartBefore(a);var e=F5_Invoke_createContextualFragment\)@\1@
Processing: Post-process response data (after content patching)
Then click "Update".
This will restore the functionality of the send button.
Best Regards,
Scott
