yarivco_99951
Jun 04, 2009self and floating ip does not reply
Hello all,
I have two ltm machines in active standby mode.
port 1 of each connect to switch A
port 8 of each connect to switch B in 802.1q and have 12 Vlans
My problem is:
I try to ping from switch a to the self and floating ip of the active machine
and i get no answer.
tcpdump on both interfaces show only echo request and no reply
Does anybody have any idea ?
- hoolio
For security reasons, BIG-IP won't response to a ping request for a self IP on a different VLAN than the VLAN the ICMP request was received on:
SOL3475: It is not possible to ping a BIG-IP self IP address from a separate VLAN
https://support.f5.com/kb/en-us/solutions/public/3000/400/sol3475.html (Click here)
Aaron - yarivco_99951
What about a Floating IP ? is it also not possible to ping it ?
I have 2 machines in an active/standby mode:
The self and th floating ip of the active machine is not answering to ping
the self ip of the backup machine is reachable via icmp.
Is it a normal behavior?
Thanks - dennypayne
Employee
Yes the same solution applies to floating IP's, this is normal.
Denny
