Stephan_Jaeger_'s avatar
Stephan_Jaeger_
Aug 16, 2007
selecting pool ignores load balancing settings
when selecting a pool with "pool " in CLIENT_ACCEPTED context it seems like the priority and loadbalancing rules for this pool are ignored. Is this correct? If so are there workarounds?
I want to select a specific pool based on the client ip, but only specific members (higher prio) in this pool should get the connections as long as the are alive.
System: BigIP 6400
OS: 9.3.0
Regards
Stephan Jaeger
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    The loadbalancing selection and priority should be intact when selecting a pool via an iRule.
    Could you show us what you're doing in the rule?
    Thanks,
    Colin
