Security headers irule issue
Hi there, i have been trying to apply an Irule to block requests for a URL when the domain is other than the ones allowed in the below rule,
switch -glob [HTTP::header "Referer"]|[HTTP::header "Origin"]|[HTTP::header "X-Forwarded-Host"] {
"xxxx.net" -
"xxxx.com"
pool emx-pool
default { HTTP::respond 200 content "
<HTML>
<HEAD>
<TITLE>Rejected Request</TITLE>
</HEAD>
<BODY>The request was rejected. <BR>The server is trying to redirect the client to an external site, but it is forbidden</BODY>
</HTML>"
The issue is, even when i am part of xxxx.net domain, i am not being sent to the default pool and keeps on hitting the rejected message body, can someone review this please?
- Yoann_Le_Corvi1
Cumulonimbus
Hi
I do not this switch -glob synthax is correct (with | to match any of the headers). You will probable have to use if, or to concatenate the thress headers before you do your comarison, taking care of input validation as thos can be altered by the client.
If I have a few minutes this afternoon, I'll try to provide you a detailed solution.
Yoann
- Yoann_Le_Corvi1
Cumulonimbus
Hopefully this does the trick π
when HTTP_REQUEST { set domains { "xxxx.net" "xxxx.com" } set matched 0 foreach header { "Referer" "Origin" "X-Forwarded-Host" } { log local0. "$header - [HTTP::header $header] : [lsearch -exact $domains [HTTP::header $header]]" if { ! ( [lsearch -exact $domains [HTTP::header $header]] equals "-1" ) } { incr matched } } if { $matched > 0 } { pool emx-pool } else { HTTP::respond 200 content " <HTML> <HEAD> <TITLE>Rejected Request</TITLE> </HEAD> <BODY>The request was rejected. <BR>The server is trying to redirect the client to an external site, but it is forbidden</BODY> </HTML>" } } - sathish_2826
Thank you Yoann for your response, i tested the rule and it is still hitting the else part and returning the body content,
One more thing i would like to highlight is, the domain for the URL is (test.xxx.net & test.xxx.com), in the rule, we are referencing the base domain (xxx.net & xxx.com), is this an issue, please take a look.
- Yoann_Le_Corvi1
Cumulonimbus
Hi
Of course. You can adapt the irule now to match precisely your search patttern.
Just replace the values I added by the real ones.
Or you can also use lsearch -glob instead of lsearch -exact.
https://www.tcl.tk/man/tcl8.4/TclCmd/lsearch.htm
Yoann
