sjko_254603's avatar
sjko_254603
Jun 30, 2017
Security audit settings and questions
Hi F5 team
I want to ask about the things I need to check. Thank you for your prompt reply and clear answer.
I have a question.
  1. What type of encryption is used for passwords in user accounts in bigip_user.conf?
  2. How do I use the SSH version and encryption method when connecting the device, and what do I use?
  3. Does our device support IEEE Std 802.1q-2011 or later?
  4. What are the encryption methods during our SNMPv3 setup and how many bits of encryption are supported?
  5. Also, what are the security features that automatically log out after a certain period of time after SSH connection?
  6. Does the syslog server work with encryption and send logs to the syslog server? If so, how do I configure it?
  7. Can I change the port numbers of SSH and HTTPS for device connection?
