Angelo's avatar
Angelo
Sep 18, 2012
Secure site giving problems
I have a secure site going through a LTM with cookie persistence, but after you logged into the site everything you click on returns to the home screen. i tested directly yo the backend and everything works but through the LTM i'm getting this behaviour.
  • Angelo's avatar
    Angelo
    the problem is this happens whenever you click on anything in the site it goes back to the original home page..
  • Angelo's avatar
    Angelo
    this is what i get from the SSLDUMP
    22 7 13.0221 (12.8559) C>S application_data
    22 8 13.0402 (0.0180) C>S application_data
    22 9 13.1254 (0.0852) S>C application_data
    22 10 13.1263 (0.0008) S>C application_data
    22 11 19.0617 (5.9354) C>S application_data
    22 12 19.0789 (0.0171) C>S application_data
    22 13 19.1596 (0.0807) S>C application_data
    22 14 19.1599 (0.0002) S>C application_data
    18 30.1445 (30.0457) S>C TCP FIN
    22 15 26.7116 (7.5517) C>S application_data
    22 16 26.7380 (0.0263) C>S application_data
    22 17 26.8225 (0.0844) S>C application_data
    22 18 26.8227 (0.0002) S>C application_data
    New TCP connection 23: psaofmrvb5.mtn.co.za(41295) <-> esf.mtn.co.za(20160)
    New TCP connection 24: psaosbrvb3.mtn.co.za(45132) <-> esf.mtn.co.za(20175)
    24 1 0.0006 (0.0006) C>S SSLv2 compatible client hello
    Version 3.1
    cipher suites
    TLS_RSA_WITH_RC4_128_MD5
    SSL2_CK_RC4
    TLS_RSA_WITH_RC4_128_SHA
    TLS_DHE_DSS_WITH_RC4_128_SHA
    TLS_ECDH_ECDSA_WITH_RC4_128_SHA
    Unknown value 0x4e
    TLS_RSA_WITH_AES_128_CBC_SHA
    TLS_RSA_WITH_AES_256_CBC_SHA
    Unknown value 0x4b
    Unknown value 0x4c
    TLS_RSA_WITH_3DES_EDE_CBC_SHA
    TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA
    TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
    TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
    Unknown value 0x50
    TLS_RSA_WITH_DES_CBC_SHA
    TLS_DHE_DSS_WITH_DES_CBC_SHA
    TLS_DHE_RSA_WITH_DES_CBC_SHA
    TLS_ECDH_ECDSA_WITH_DES_CBC_SHA
    Unknown value 0x4f
    TLS_RSA_EXPORT1024_WITH_RC4_56_SHA
    TLS_DHE_DSS_WITH_RC2_56_CBC_SHA
    TLS_RSA_EXPORT1024_WITH_DES_CBC_SHA
    TLS_DHE_DSS_EXPORT1024_WITH_DES_CBC_SHA
    TLS_RSA_EXPORT_WITH_RC4_40_MD5
    SSL2_CK_RC4_EXPORT40
    TLS_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA
    TLS_DHE_RSA_EXPORT_WITH_DES40_CBC_SHA
    TLS_RSA_EXPORT_WITH_DES40_CBC_SHA
    TLS_DH_anon_WITH_3DES_EDE_CBC_SHA
    TLS_DH_anon_WITH_RC4_128_MD5
    TLS_DH_anon_WITH_DES_CBC_SHA
    TLS_DH_anon_EXPORT_WITH_RC4_40_MD5
    TLS_DH_anon_EXPORT_WITH_DES40_CBC_SHA
    24 2 0.0007 (0.0000) S>C Handshake
    ServerHello
    Version 3.1
    session_id[32]=
    d5 91 33 41 e8 7c d9 c7 3e 70 ee f5 c3 82 a9 93
    e6 71 96 cb 4b 90 47 b0 6e 1f 7a ef 2e 82 d4 57
    cipherSuite TLS_RSA_WITH_RC4_128_SHA
    compressionMethod NULL
    24 3 0.0007 (0.0000) S>C Handshake
    Certificate
    24 4 0.0007 (0.0000) S>C Handshake
    ServerHelloDone
    24 5 0.0031 (0.0024) C>S Handshake
    ClientKeyExchange
    24 6 0.0031 (0.0000) C>S ChangeCipherSpec
    24 7 0.0035 (0.0003) C>S Handshake
    24 8 0.0062 (0.0027) S>C ChangeCipherSpec
    24 9 0.0062 (0.0000) S>C Handshake
    24 10 0.0072 (0.0010) C>S application_data
    24 11 0.0072 (0.0000) C>S application_data
    24 12 0.0076 (0.0003) C>S application_data
    New TCP connection 25: psaofmrvb4.mtn.co.za(52045) <-> esf.mtn.co.za(20160)
    25 0.0192 (0.0192) C>S TCP FIN
    25 0.0197 (0.0004) S>C TCP FIN
    New TCP connection 26: psaofmrvb4.mtn.co.za(52046) <-> esf.mtn.co.za(20160)
    24 13 0.3411 (0.3334) S>C application_data
    24 14 0.3412 (0.0000) S>C application_data
    24 15 0.3412 (0.0000) S>C application_data
    22 19 29.1491 (2.3263) C>S application_data
    22 20 29.1654 (0.0162) C>S application_data
    22 21 29.2472 (0.0818) S>C application_data
    22 22 29.2481 (0.0008) S>C application_data
  • Okay, your post before last was helpful. You indicate that, after logon, any link you click generates the same exact POST request and returns back to the home page. At this point it's very likely that the application logic doesn't like what it's getting from the proxy and is trying to get the user back on track. Your best bet then into compare the initial requests and responses to the site, up to and including this POST request in both the proxied and non-proxied environments.
    You didn't answer whether the virtual server was using an iRule or any special configuration(s).
    Also, if you turn off client side SSL on the BIG-IP does it make a difference?
  • Angelo's avatar
    Angelo
    I have a irule that rewrites the content in the XML WSDL to https. this is the config https (Client side) http (server side) this is my config
    ltm virtual vs_soa_bpm_prd {
    destination 10.217.235.116:20176
    ip-protocol tcp
    mask 255.255.255.255
    partition SOA
    persist {
    /Common/dest_addr {
    default yes
    pool pool_soa_bpm_prd
    profiles {
    /Common/mtn.co.za {
    context clientside
    /Common/oneconnect { }
    /Common/tcp { }
    SOA_Profile { }
    SOA_expression { }
    rules {
    Streaming_SOA_Prod
    /Common/CRM
    snat automap
    vlans-disabled
  • Hmmm, that doesn't sound like a great idea to me considering that the HTTP Content Length header won't be modified to match the increased size. This probably explains your issue with the client constantly reposting; it's not accepting the response as valid. Could you modify your server configuration or WSDL to return https:// links instead?
  • Angelo's avatar
    Angelo
    this was the requirements i received from the solutions architect. this is the what the irule does...
    STREAM::disable
    HTTP::header remove "Accept-Encoding"
    when HTTP_RESPONSE {
    if {[HTTP::header value Content-Type] contains "text"}{
    STREAM::expression {@http://esf.mtn.co.za@https://esf.mtn.co.za@}
    STREAM::enable
  • Yep, that'll break things pretty well I'd say although I'd expect it to break things straight away, not just after you authenticate. Do you initially connect using http?
  • Angelo's avatar
    Angelo
    all communications on the client side is done https
  • That may or may not be true depending on your version. Prior to 9.3 you might need to set the Rechunking option in the HTTP profile, but that shouldn't be the case anymore with STREAM expressions.
    https://support.f5.com/kb/en-us/solutions/public/6000/400/sol6422.html
    So what it looks like you're trying to do is replace all instances of the HTTP URL with HTTPS. The stream profile will look at payload. You can set the Redirect setting in the HTTP profile to either ALL or MATCHING to get the BIG-IP to replace HTTP references in 30x redirects. Otherwise, you still need to compare the request and response traffic between the working and non-working environments. My guess is that you're either not catching something in your iRule, or some other value is slipping through/changing that the application can't use.
  • Angelo's avatar
    Angelo
    Figured out what was wrong. in my streaming profile i had source http destination https instead of a blank profile...
