JN's avatar
JN
Oct 05, 2012
script or ?? to pull LTM serial number
Does anyone have a script (powershell?) or some kind of icontrol that can be run from a windows server on the same subnet that will pull and display or save the serial number of the BIGIP LTM? v10 and v11.
  • Add-PSSnapin iControlSnapIn
    Initialize-F5.iControl -HostName [hostname] -PScredentials (get-credential)
    (Get-F5.iControl).managementpartition.set_active_partition('YourPartition')
    $f = Get-F5.iControl
    $f.SystemSystemInfo.get_system_information()
    this will list just the serial
    ($f.SystemSystemInfo.get_system_information()).chassis_serial
    Ben
  • Thanks for the tip Ben! Glad to see there are other PowerShell users out there!
    -Joe
