Brian_Patton_17's avatar
Brian_Patton_17
7 years ago
ScaleN monitoring with SNMP?
When using ScaleN to have Virtual Servers active across multiple LTM VEs, is there a way to determine which LTM is active/passive for individual traffic-groups via SNMP monitoring?
There does not appear to be MIB libraries in 13.1 that identify this data. Did I miss it?
Thanks,
  • Hey Brian
    Not sure if you're monitoring tool will be able to sort this out but using the mib: F5-BIGIP-SYSTEM-MIB::sysCmTrafficGroupStatusFailoverStatus, you will be able to see the individual status of each traffic group. In my case I only have the default traffic-group-1 but I can see that it is presently active on bigipcore02. Please see below:
    [root@bigipcore01:Standby:Changes Pending] config  snmpwalk -v2c -c public localhost 1.3.6.1.4.1.3375.2.1.14.5.2.1.3
    F5-BIGIP-SYSTEM-MIB::sysCmTrafficGroupStatusFailoverStatus."/Common/traffic-group-1"."/Common/bigipcore01.com" = INTEGER: standby(3)
    F5-BIGIP-SYSTEM-MIB::sysCmTrafficGroupStatusFailoverStatus."/Common/traffic-group-1"."/Common/bigipcore02.com" = INTEGER: active(4)
    It uses the OID 1.3.6.1.4.1.3375.2.1.14.5.2.1.3
    If you can get your monitoring tool to only display the traffic groups which are "Active" then you will be able to get the data.
    I hope this helps 🙂
