Fereda_187281's avatar
Fereda_187281
Oct 09, 2017
Same Nodes Different Partitions?
Hi all,
I have 3 nodes bind 1 pool and that pool bind a VIP under a partition A. They are all created under partition A I want to create new partition and we will use same servers /nodes in VIP under partition B. I don't use nodes for new pool members when select partition B , because they are all under partition A. I know , I have to recreate nodes under common then i can use nodes all pools under both of partitions. My ask that how can i use nodes which are under partition A for partition B? Is it any possibility?
  • Hi,
    Partition objects are not available from other partitions. it is the goal of partitions.
    Only Common partition objects are available from other partitions.
    I advice all customers to create nodes in Common partition before create pool members.
    if you want to use the node in 2 partitions, you have to move it to Common.
