Krishna_R's avatar
Krishna_R
Nov 12, 2015
Running out of existing IP subnet
Need help! I am using a particular subnet 10.X.21.X/24 to configure any web applications on the load balancer as a VIP. However, i am running out of IPs and need to add 10.x.22.x/24 as a new range where the load balancer can accept the traffic.
What do i do in order for configuring the same on the load balancer?
  • You just need to ensure that network is being routed to the LTM. You don't even necessarily need to have a selfIP in the new network, though you could if you wanted to. But you could just route 10.x.22.x/24 to the floating slefIP in your 10.x.21.x/24 network.
