mr_skater99_640
Aug 08, 2011Ruby Issues
Hi Guys,
I've used this page as a guide of sorts (http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1086421/Getting-Started-With-Ruby-and-iControl.aspx)
I've got ruby 1.9.2p0 (2010-08-18 revision 29036) [x86_64-linux] and gem version 1.8.7 on Debian 6 64bit.
I've installed both the httpclient and soap4r gems.
The first issue i ran into running get-version.rb was:
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/xsd/charset.rb:13: warning: variable $KCODE is no longer effective
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/xsd/xmlparser.rb:74:in `': XML processor module not found. (RuntimeError)
from /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/wsdl/parser.rb:12:in `'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/wsdlDriver.rb:9:in `'
from /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:59:in `require'
from /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:59:in `rescue in require'
from /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:35:in `require'
from /usr/lib/ruby/gems/1.9.1/gems/f5-icontrol-10.2.0.2/lib/f5-icontrol.rb:2:in `'
from get-version.rb:4:in `'
Which was fixed by editing /usr/local/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/xsd/xmlparser.rb as suggested on this page (
http://railsforum.com/viewtopic.php?id=41231).
Now i am getting this:
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/property.rb:68: warning: encoding option is ignored - u
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/property.rb:69: warning: encoding option is ignored - u
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/property.rb:70: warning: encoding option is ignored - u
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/rpc/element.rb:226: warning: Hashindex is deprecated; use Hashkey
/usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/generator.rb:276: warning: encoding option is ignored - UTF8
Long pause then:
/usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:276:in `connect': execution expired (HTTPClient::ConnectTimeoutError)
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:276:in `ssl_connect'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:712:in `block in connect'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:704:in `connect'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:568:in `query'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient/session.rb:158:in `query'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:1057:in `do_get_block'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:866:in `block in do_request'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:953:in `protect_keep_alive_disconnected'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:865:in `do_request'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:753:in `request'
from /usr/lib/ruby/gems/1.9.1/gems/httpclient-2.2.1/lib/httpclient.rb:663:in `post'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/streamHandler.rb:238:in `send_post'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/streamHandler.rb:172:in `send'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/rpc/proxy.rb:179:in `route'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/rpc/proxy.rb:143:in `call'
from /usr/lib/ruby/gems/1.9.1/gems/soap4r-1.5.8/lib/soap/rpc/driver.rb:181:in `call'
from (eval):6:in `get_version'
from get-version.rb:15:in `'
I've checked an i have access to the host (telnet ip on 443). Do the default self signed certs cause this???
Anyone else got any other ideas???
Thanks.
- mr_skater99_640
My bad - had a proxy set in the terminal i was working in.
Unsetting $http_proxy fixed it! - utulavi_95527
I am facing the same issue and came across this post. I can't telnet to 192.168.1.245 on 443. Is this still valid for you?
Appreciate your response.
Thanks. - mr_skater99_640
Hi Utulavi,
My issues was solved by fixing the proxy environment variable ont eh linux host i was working on.
Cheers,
Scotty
