jimbo_8321
Jan 10, 2010RTSP load balancing in old F5
Please can you give me some help with RTSP streaming.
I need to buy an older (due to budget) F5 product.
Which of the F5 older range support RTSP load balancing?
I need a switch that will allow A streaming session with:
1 x RTSP/TCP session opened two ways between server and mobile phone,
1 way RTP/RTCP/UDP session from server to phone and
1 way RTCP/UDP session from handset to server.
These sessions are not correlated with each other only at the application level.
Is it only the machines which support Local traffic manager? If not what F% products (older) can i buy?
many thanks in advance - really appreciate your advice.
Jim
- hoolio
Hi Jim,
I'd suggest you contact an F5 salesperson to find out which LTM versions (and platforms) provide the support for RTSP you need. See your other posts for a few related links:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=814572&ptarget=814578
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=2063&tpage=1&view=topic&postid=814572
Aaron
