Chris_Stamm_183
20 years agoRPC load balancing among multiple tiers using iRules, pools and forwarding
Scenario:
We have an app that uses...
TCP port 7496 for one piece.
TCP port 3372 for another piece.
TCP port 135 for DTC that will renegotiate a high port in this case we set the RPC range for AppServerA to 40000 to 40999, AppServerB to 41000 to 41999, AppServerC to 42000 to 42999, AppServerD to 43000 to 43999, AppServerE to 44000 to 44999. We do this so that we can load balance RPC by saying if the port negotiated is between 42000 and 42999 then we know we send that to AppServerD.
Our application is tiered where we have a web layer that is load balanced, an application layer that is load balanced by the above configuration and finally a database layer that does not load balance but does require the same ports as above. The environment looks something like this. BigIP (BigIPWeb) connected on external interface to internet and internal interface to web layer. Bigip (BigIPApp)connected on external interface to web layer and internal interface to app layer. Firewall connected on external interface to app layer and internal interface to database layer.
Incoming web requests are good but here is what I need to do for the app to communicate properly (I am already doing this on 4.5 but 9.x is quite a bit different)...
Web request comes in through BigIPWeb and gets LB'd to WebServerA. WebServerA needs to make request to the application layer VIP on port 7496 initially, then initiates another request to application layer VIP for port 135 (has to be the same VIP for all application layer traffic - not necessarily same node) which will renegotiate depending on the app server that gets the request on 135 - in this instance lets say AppServerA gets the 135 port so the negotiated port must lay between 40000 and 40999. After all that is done one last communication happens which is all from a lower tier to a higher tier i.e. sql to app or app to web.
So to sumarize we need to LB port 7496 to a five nodes, 135 to five nodes, 40000-40999 to AppServerA, 41000 to 41999 to AppServerB, 42000 to 42999 to AppServerC, 43000 to 43999 to AppServerD, 44000 to 4$999 to AppServerE and finally upward traffic on 3372.
I intend on doing this with two iRules which are here...
This is the inbound to app VIP.
APP_POOL will have servers AppServerA, AppServerB, AppServerC, AppServerD, AppServerE.
AppServerA will have AppServerA in pool with port set to 0 (to include all)
AppServerB will have AppServerB in pool with port set to 0 (to include all)
and so on up to AppServerE
VIP is set to this
when CLIENT_ACCEPTED {
if { [TCP::server_port] == 7495 }
pool APP_POOL
elseif { [TCP::server_port] == 135 }
pool APP_POOL
elseif { [TCP::server_port] > 39999 and [TCP::server_port] < 41000 }
pool AppServerA
elseif { [TCP::server_port] > 40999 and [TCP::server_port] < 42000 }
pool AppServerB
elseif { [TCP::server_port] > 41999 and [TCP::server_port] < 43000 }
pool AppServerC
elseif { [TCP::server_port] > 42999 and [TCP::server_port] < 44000 }
pool AppServerD
elseif { [TCP::server_port] > 43999 and [TCP::server_port] < 45000 }
pool AppServerE
elseif { [TCP::server_port] == 3372 }
forward
else {
discard
}NetworkBasedVIP set to this for access to APP network for DTC forwards and callbacks...
forward
forward
forward
forward
forward
forward
forward
forward
else {
discard
}NetworkBasedVIP set to this for access to DATABASE network for DTC forwards and callbacks...
forward
forward
forward
forward
forward
forward
forward
forward
else {
discard
}13 Replies
