JQUINONES82NB's avatar
JQUINONES82NB
Jan 25, 2019
Routing vlan traffic between route domains and parititions
I have old physical f5s that have to partitions with route domains
partition 1 has vlan 1 and vlan 2
partition 2 has vlan 3
Is there a way to allow communication between the two paritions bidirectionally?
Looking at the route table on each partition, I can not see the self ips on the different route paritions.
  • By default, route domains use "Strict Isolation", which means that routes cannot cross route domain boundaries (so they are strictly isolated to the current route domain). If you disable this option on both route domains, then you should be able to create routes that meet your requirements.
