BDunbar_8799
Feb 08, 2011Routing traffic to remote sites using LTM
We have version 2 of an in-house application coming up. It has been decided that our F5 LTMs will be the front end to manage traffic.
There will be regional application servers, IIS. End users login to those. The question is the best way to tell a user at Site X to login to Site X's regional server.
The proposed method is for each client to use domain suffix search order to find the closest resource. Thus a client.juarez.company.com would find shop-floor.juarez.company.com. Neat and tidy.
I wondered if using an iRule would be a better solution. We know all users will be internal, we know our subnets [1] so if we assume ...
F5 LTM ver 9.4.6
Cluster
Located in the same subnet as global.company.com, at global headqarters.
subnets
Penang = 10.0.1
Xiamen = 10.0.2
Jaurez = 10.0.3
GHQ = 10.0.4
Pools
GSF_PD_PENANG
member: shop-floor.penang.company.com
GSF_PD_XIAMEN
member: shop-floor.xiamen.company.com
GSF_PD_JUAREZ
member: shop-floor.juarez.company.com
GSF_PD_GLOBAL
member: global.company.com
With an IRULE
pseudo-TCL
when CLIENT_ACCEPTED {
if {[IP::addr "[IP::client_addr]/24" equals "10.0.1/24"]} {
pool GSF_PD_PENANG
else if {[IP::addr "[IP::client_addr]/24" equals "10.0.2/24"]} {
pool GSF_PD_XIAMEN
elseif {[IP::addr "[IP::client_addr]/24" equals "10.0.3/24"]} {
pool GSF_PD_JUAREZ
else
{pool GSF_PD_GLOBAL}
1. Would this be viable?
2. The first question raised was 'would this mean traffic is routed from the the site, to the F5 LTM, then back to the site where the shop-floor.location.company.com server is?' Would it?
[1] Yes, I know these are not valid subnets. Example use only.
- hoolio
If all the connections are being proxied through the same LTM pair, it doesn't really matter if the servers are close to the clients. You'd just want to use the pool of servers closest to LTM. Now, if you're able to have the clients connect directly to the servers (or an LTM in the regional datacenter), then you'd want to use the servers closest to the client. If the clients can connect directly to the servers, you could use your logic or do a GeoIP lookup using the whereis command and redirect the clients to an IP address or hostname which points to the closest regional servers.
Aaron
