routing Issues on F5
Hi F5 Team,
How can this 2 ip segment communicate on F5.
Config Details: F5 port 1 with self ip 192.168.50.1/26 with direct client pc ip 192.168.50.10/26 gateway to F5 192.168.50.1 F5 port 2 with self ip 192.168.51.1/26 with direct client pc ip 192.168.51.10/26 gateway to F5 192.168.51.1
Testing: On 192.168.50.10 PC, i want to ping the 192.168.51.1 self ip of port 2 and PC 192.168.51.10 On 192.168.51.10 PC, i want to ping the 192.168.50.1 self ip of port 2 and PC 192.168.50.10
Thanks!
Goldz
- DevBabu
Cirrus
What's your issue ? Is icmp packet not reaching F5 box or the packet is not getting out ? How does your routing table looks like in the box ? I hope they should communicate with default settings if icmp is not blocked. Still have issues, I would try creating wildcard forwarding virtual server with all protocols enabled. Thanks - Goldz_180077
i have no routing, i only created forwarding ip vs any any. the issues is, ping from pc to pc. - Arnaud_Lemaire
Employee
Could you check on the forwarding virtual server that protocol is set to All protocol, bu default it's tcp only.
then a pcap on the bigip could probably help.
- DevBabu
Cirrus
captures will definitely help. Please take capture to share.
