Jimb2k_159873's avatar
Jimb2k_159873
Jun 04, 2014
Routing Between DMZ & LAN using F5
Hello Everybody,
I'm new on the F5 world, and I have a question about a configuration that I'll want to simulate using F5.
This is related to Vmware View architecture, that's the security server must reside on the DMZ network.
But all the rest of the servers reside on the LAN network.
So for that I want to use F5 with its functions, plus routing the traffic between the two networks.
I hope that I give an approach scenario of my issue.
Thanks in advance
  • So what will be the solution at your opinion please.
    have you tried to ping server ip (not self ip)? pinging server ip should work.
  • Hello Guys,
    Thank you for your support.
    Finally, This is working for me.
    It's related to the Vswitch that I assigned to the Nic cards.
    After Do this, the configuration was right and the ping between the host working as charm.
    Thank you very much again and again.
