Jeff_Wyant_4852's avatar
Jeff_Wyant_4852
Feb 03, 2011
Route Traffic Based on Header Info
Problem:
I need to route traffic coming into a single virtual server, inspect the header info, and if the condition matches, send it to another pool while leaving traffic that doesn't match the condition in the original virtual server resource pool. The condition I'm trying to match against is shown in this packet capture: "X-Forwarded-For: 64.238.106.226, 216.66.8.30"
_________________________________________________________________________________________________
GET /imageserver/d_31167/w_92/h_69/np/2C3LA63H06H159009-8.jpg HTTP/1.1
Accept: */*
Referer: http://www.mysite.com
Accept-Language: en-us
UA-CPU: x86
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; .NET4.0C)
X-Akamai-CONFIG-LOG-DETAIL: true
TE: chunked;q=1.0
Connection: TE
Accept-Encoding: gzip
Akamai-Origin-Hop: 2
Via: 1.1 v1-akamaitech.net(ghost) (AkamaiGHost), 1.1 akamai.net(ghost) (AkamaiGHost)
Host: api.cdmdata.m7z.net
Cache-Control: max-age=86400
Connection: keep-alive
Here is the iRules I've been trying:
if { [HTTP::header "X-Forwarded-For"] contains "64.238.106.226" }{
pool mysite
when CLIENT_ACCEPTED {
if {[matchclass [HTTP::header "X-Forwarded-For"] contains "63.243.106.226"]} {
pool mysite member 10.1.1.1}{
log local0. "X-Forwarded-for redirect match 63.243.106.226."
Any Suggestions?
-Jeff
  • This rule assumes you change "default" below to the pool you'd like non-matching traffic to use. Also, you'll want to use OneConnect to ensure the HTTP info is evaluated and traffic is sent accordingly.
    More can be read about that here:
    http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/114/OneConnect-For-my-iRule.aspx
    Finally, you can either make a list of addresses in a "class/data group" and check whether they exist, or you can specify them from within the rule. How many addresses do you have total to check? that can influence whether you go one way or the other.
        if { [HTTP::header "X-Forwarded-For"] contains "64.238.106.226" } {
             pool mysite }
       else { pool default }
