Reverse Monitor Syntax to match Status Code 500-509
Hi
I'm trying to use a reverse monitor to mark any servers in a pool down that return a status code of 500-509. I'm unable to get this to work and I'm hoping someone will be able to help me. Currently I'm trying to match the following:
< HTTP/1.1 503 Service Unavailable
I'm using the following Receive String:
HTTP\/1.[01]\s50[0-9]
But this doesnt seem to match the above status code. Therefore if anybody could help me with this is would be greatly appreciated.
Malc
Try this one?
HTTP/1.[01] 50[0-9]/Patrik
- nitass
Employee
sol5917: Using regular expressions in a health monitor Receive String
http://support.f5.com/kb/en-us/solutions/public/5000/900/sol5917.htmle.g.
config [root@ve11a:Active:In Sync] config tmsh list ltm monitor http myhttp ltm monitor http myhttp { defaults-from http destination *:* interval 5 ip-dscp 0 recv HTTP/1\.[01]\s40[0-9] reverse enabled send "GET /fake.html HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n" time-until-up 0 timeout 16 } test [root@ve11a:Active:In Sync] config tmsh list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 session monitor-enabled state down } } monitor myhttp } trace [root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 200.200.200.11(39804) <-> 200.200.200.101(80) 1402421687.8100 (0.0248) C>S --------------------------------------------------------------- GET /fake.html HTTP/1.1 Host: Connection: Close --------------------------------------------------------------- 1402421688.4348 (0.6247) S>C --------------------------------------------------------------- HTTP/1.1 404 Not Found Date: Tue, 10 Jun 2014 17:23:53 GMT Server: Apache/2.2.3 (CentOS) Content-Length: 272 Connection: close Content-Type: text/html; charset=iso-8859-1 ...snipped... --------------------------------------------------------------- - Malcolm_Salmon1
Hi
THanks for the responses. I actually decided to swap this round and look for positive responses in the ranges 200-400 instead of 500 for a negative response. I managed to get this working using the following:
Send string:
HEAD / HTTP/1.0\r\n\r\n
Receive string:
HTTP/1.[01] ([234]0[0-9])
Malc
