martek_58308's avatar
martek_58308
Aug 03, 2016
Solved
REST - setSyncLeader in device-group
Hi guys,
Need a help with another bit of REST config - bellow is TMSH command to do this
modify cm device-group DEVICE_GROUP_NAME devices modify { DEVICE_NAME { set-sync-leader } }
and I though that "mgmt/tm/cm/device-group/devices" suppose to do this same
However I can't do even GET to this and is returning "Object not found - devices" then I though - well maybe I should specify which device group I want to query so my new REST command looked like bellow
https://x.x.x.x/mgmt/tm/cm/device-group/~Common~device_trust_group/devices
and this returned me my two devices in this group - however there is no option for "setSyncLeader"
I tried POST as well which in my opinion should looks like either
https://x.x.x.x/mgmt/tm/cm/device-group/~Common~device_trust_group/devices/~Common~lb01a.tst.com
with body like
{ "setSyncLeader": true }
or I tried as well option like bellow
with body like bellow
{ "name": "lb01a.tst.com", "setSyncLeader": true }
Both returned : The requested device group device (/Common/device_trust_group /Common/lb01a.tst.com) already exists."
I run out of ideas tbh and any help really appreciated - I can probably run TMSH command but prefer not to
Regards, Marcin
  • Terse answer.. I am typing on phone traveling..
    You woukd not use POST in the device group as you are working with an existing group, not creating one.
    I believe you want to use the PATCH verb on the full devicegroup / devices / device URL.
  • John_Gruber_432's avatar
    John_Gruber_432
    Historic F5 Account
    • martek_58308's avatar
      martek_58308
      Hi John,
      Thx for the clue - sometimes the simplest solution are hidden in front of our eyes
      Regards, Marcin
  • I'm doing the same in a shell script using PUT as http method. Maybe the snippet will help you:
    lb=my_bigip_fqdn
    dg=device_group_name
    lb_commit() {
      local lb_name=$1
      local rest_object_path=$2
      local http_uri=/mgmt/tm"$rest_object_path"
      local http_method=$3
      local json_data=$4
      echo $(curl --insecure -1 -sk -u admin:$adminpw https://$lb_name$http_uri -H 'Content-Type: application/json' -X $http_method -d "$json_data")
    result=$(lb_commit $lb /cm/device-group/~Common~$dg/devices/$lb/ PUT "{\"set-sync-leader\":true}")
    echo $result
