Peo's avatar
Peo
Sep 24, 2019
Reset connection via iControl
Hi!
I have written an AI that does some analyzing and sometimes decides that an IP no longer should be
allowed to access a specific resource.
When this happens, the IP is added to a data-group-list and the resource has an iRule that checks if
the IP is blocked via the CLIENT_ACCEPTED-event.
Problem: The current connection is allowed to persist since the drop in only done when a new connection
is set up (due to using the CLIENT_ACCEPTED-event).
I have been looking through the iControl API to see if I can drop a specific connection based on IP but
I can't find anything about networking at all.. Any ideas how to solve this?
Since the resource get a lot of request, it would not be very good to check the DGL on every incomming request.
Product: BIG-IP
Version: 13.1.1
Build: 0.0.4
BIG-IP 4000S
