Eric_Jongeling's avatar
Eric_Jongeling
5 years ago
Removing disused networking from F5 LTM
What is the correct way to remove a disused interface from an F5 LTM running 12.1.3. There are no nodes or virtual servers using this network/interface any longer.
We have a VLAN associated with an untagged interface, associated with a member (nic 1.2) and 3 self-IPs. One for each node and the floating interface.
Any help would be appreciated.
  • i would check with search through the text config if there are no references, then:
    first remove the floating IP, sync config
    then remove the node self IP on both nodes
    continue with removing the VLAN on both nodes
