abeny_894
May 15, 2006Remote syslog
Dear all,
Can somebody help me that how can configure or use irules to remote syslog logging? it is works that only logging in the bigip
what i need to config if i need remote syslog logging?
Many thanks ~
- Jason_Roppolo_3Historic F5 AccountHi!
Under /etc/syslog-ng/syslog-ng.conf
You need to modify the configuration where it says:
destination d_ltm {
file("/var/log/ltm" create_dirs(yes));
to something like:
destination d_ltm {
udp("x.x.x.x");
This is assuming that what you are looking for is logging to var/log/ltm
Once you make the change you need to do a bigstart restart syslog
I would be careful doing this on a production system!
-J - abeny_894
MANY THANKS~ IT WORKS~
