Remote shutdown of 3600 device
Could someone tell me how to remotely shutdown a 3600 device using either the configuration utility or the command line? I see a reference to the halt command, but I am not sure at what prompt to enter the command. Device is running version 12.1.2.
Thanks Eric
- jaikumar_f5
Noctilucent
You can issue the below command,
shutdown -hP nowh - halt. P - power off.
If you are using the tmsh shell, you should be able to simply run "shutdown".
Otherwise to use the command posted by jaikumar, you would need to run it from the bash shell. If you're in the tmsh shell, then you would access the bash shell first using run /sys bash.
