Remote logs through Management interface.
I have configured remote syslog server and configured management ip as source ip but I am still getting logs through self ip instead of management interface. Although I have configured default management route and syslog server is accessible through that route.
- nathe
Cirrocumulus
You've probably seen this Askf5 SOL: Overview of management interface routing
From this doc it suggests a static route is required if the endpoint is not on the same subnet as the management network. Obviously you don't mention whether this is the case or not but if it isn't on the same subnet then a static route will hopefully help here.
Rgds
N
