paul_73820's avatar
paul_73820
Nov 06, 2012
regex for a number between 1-99
Hi There,
I am trying to validate a string with that is like this:
pw-10:1000.100
The regex i am using is:
^pw-[1-9]\d?
This works in perl, and infact in tcl 8.5 but doesnt match in the irule for some reason.
the tcl i am using to see if it work is:
set string "12 Again and again and again ..."
if { [regexp {(^[1-9]\d?)} $string => digits] } {
puts "we got $digits in string"
puts "nothing here"
The irule is like this:
switch -regex $string {
"^pw-[1-9]\d?:" {
do some stuff
default {
There is more of course but you get the idea.
Any ideas?
Paul
  • I think i see the issue.
    i wasnt separating ?: so it fails.
    Doing ^pw-([1-9]\d?): works fine.
  • hoolio's avatar
    hoolio
    Hi Paul,
    If you can use a string or scan command it should be more efficient than regexp:
    switch -glog $str {
    pw-[1-9]* -
    Note that I didn't check for the optional digit following 1-9 as you had it listed as optional in your regex.
    Aaron
  • Thanks hoolio,
    I think you mean glob ;)
    If you use glob is it a string match?
    I was using regex as we had a number of tricky strings that were evaluated in the same switch, thats not the case now so might be time to review and drop the regex.
    I havent noticed any real impact due to regex yet.
    Paul
