Regarding Perl Command help
Hello Team, I am trying below command but getting error, plz help to resolved this issues as I have to replace cisco ACE to F5..... Command: perl ace2f5-tmsh.pl /config/aceconfig.txt >newbigip.conf
Error: "Perl v5.12.0 required--this is only v5.8.8, stopped at ace2f5-tmsh.pl line 37"
Thanks.. Sanjay
- Kevin_Davies_40
Nacreous
You are not running the required version of Perl. Do your conversion on a machine that has at least version 5.12.
- Sanjay_Yadav_17
I upgraded the version of F5 box but still same issues... Actually F5 support v5.8.8 ,so do u have any other way to deport cisco ACE back into F5 device.
- Kevin_Davies_40
Nacreous
You do not need to run this on a BIGIP. It creates a tmsh script which you can then run on a BIGIP.
- Sanjay_Yadav_17
How it work... plz share any doc or guide for the same...
