Shoaib_020's avatar
Shoaib_020
Mar 03, 2024
Regarding custom monitor for multiple pool members
I have three pool members and I wanted to create a custom monitor. The pool member will response with string "GREEN" in response to
https://pool_member_ip/inside/nzvi/poll
when I am creating a monitor with the following send and receive string as:
send string -  GET /inside/nzvi/poll HTTP/1.1\r\nHost: pool_member_1_ip\r\nConnection: Close\r\n\r\n
receive string - GREEN
only pool member 1 is showing up, rest pool member 2 and pool member 3 are showing down.
if I change the IP in the send string to pool member 2 IP, pool member 2 will show up and other two members will show down and so on.
pls help me how I create the send string to accommodate all the pool members.
  • This depends on the configuration of your backend servers, here's a few things to test:
    1. Send the application hostname in the host header instead of the ip address.
    2. Send an empty host header (Host: \r\n)
    3. If the above don't work, this means that your backend server requires explicit host header to identify the resource to serve. In this case, you can create three custom monitors, one for each pool member, and within the member configuration override the 'inherit from pool' default monitor setting and select the appropriate monitor
  • because the intended value is pool member's IP address, then you dont need to specify the value for the Host header because  it is default value used by LTM monitor.
    Connection: close and HTTP/1.1 things are also not needed as LTM monitor will use the TCP connection for 1 requset and properly close it after getting response.
    • Shoaib_020's avatar
      Shoaib_020
      Okay. So the send string will look like as below right ?
      GET /inside/nzvi/poll \r\n Host: \r\n
    • Amine_Kadimi's avatar
      Amine_Kadimi
      Icon for MVP rankMVP
      This is not correct. Please be aware of these basic http monitors concepts:
      • If you don't specify the HTTP version, then the monitor will default to version 0.9 which is not supported by many web servers
      • If you need to talk to a server using HTTP/1.1, then you need to specify a Host header, although its value can be empty
      • Connection: close is not mandatory but a good practice to be sure servers implementing keep alives do close the connection
