KSingh's avatar
KSingh
Aug 05, 2022
Reference architecture for VPN infrastructure using BIG IP?
Does anybody has any reference architecture for VPN infrastructure using BIG IP? As most of the employees are remote nowdays ,what is best deployment model to increase the resilency of VPN infra?
  • if you want to configure VPN for normal Employees better to configure Zero Trust Application Access using APM portal access with AD auth and OTP even client side compliance policy that assigned to Application Tunnel and Portal Access or even RDP policy to use their organization PCs such as below example from F5:-
