Frank_Mancini_3's avatar
Frank_Mancini_3
Feb 11, 2008
redirection for SSL without cert HELP
If I have a virtual interface configured for TCP 443 and I have a redirection iRule to a correct good URL:
HTTP::redirect "https://www.mysite.com"
and I type of the https://ip address of the virutal interface, will I get the "Not a valid ssl site" message before the redirection occurs?
  • hoolio's avatar
    hoolio
    When you make a request to an HTTPS web server and the server responds with a certificate, the browser compares the subject of the cert with the host name it made the request to. If they don't match, and the browser isn't configured to ignore cert mismatch errors, the browser will generate a cert mismatch error. As you're making a request by IP address, the cert subject won't match and you'll get the browser warning.
    If you make a request which matches the cert's subject, do you still get a warning? Are clients requesting host names which don't match the cert's subject? If so, take a look at this post (Click here) for some additional info.
    Aaron
