redirection 80 to 443 and http to https without creating pools and virtuals
How can I create any http requests redirect/convert to https requests without creating 80 pools or virtual.
Any helps would be appricate
- JG
Cumulonimbus
Well, not a redirect, but implementing "HTTP Strict Transport Security" will accomplish a similar result.
It is supported out-of-box since v12.0.0. From the Release Notes of that version:
HTTP Strict Transport Security (HSTS) functionality
In this release, an HTTP profile provides HTTP Strict Transport Security (HSTS) settings that apply HSTS security functionality. This functionality requires all non-secure HTTP traffic to use secure HTTPS connections for both a domain (and optionally its subdomains) and persisting client HSTS security functionality, for a specified period.
Or it can be implemented via an irule. See: https://devcentral.f5.com/articles/implementing-http-strict-transport-security-in-irules .
Anyhow, this will at least draw your attention to the security issues of an HTTP->HTTPS redirect so frequently requested.
- Desai_124243
Thanks reply back. my virtual configuration is on Fastl4 and link is showing http_request irule which is not supported by fastl4. And we are using 10.2 version in F5. do u have any solution where I can keep fastl4 profile and implement redirection.
Regards
- Mike_Dayton_108
Fastl4 does not deal with application level processing. The HTTP is not seen by the proxy when FL4 is used. Because the http is not processed, you cannot redirect using http.
