Jon_46029
May 16, 2012Redirecting a client when "connection refused" by pool
When all of the pool members are down for a Virtual Server (VS), we're seeing a connection refused error at the browser.
I'd like to catch that in the F5 LTM with an iRule and direct the browser to a different site hosting a maintenance status message.
Without an existing HTTP session, though, there's no 404 data and HTTP::* events don't appear to be setup. (HTTP::redirect won't work on SERVER_CLOSED which appears to be the only event I can find that traps the condition).
Suggestions?
Jon
- nathe
Cirrocumulus
Jon
Is the different site you want to forward users to an external web address? If so would this work?
when CLIENT_ACCEPTED {
if { [active_members [LB::server pool]] == 0 } {
HTTP::redirect "http://www.test.com"
You could always use Priority Group Activation so you can add another pool member to the pool that just has an maintenance page on it and set this pool member to only be live if all the other pool members are down. In this case you could always use an old, low spec server as the fallback here.
Hope this helps,
N - John_Alam_45640Historic F5 Account
Here is Nathan's iRule with small modification: (works well for http and https)
Priority grouping is a good idea too.
To answer Jon's question, as to: which event catches the condition of "NO members available", that would be the LB_FAILED event.
Check out this link:
https://devcentral.f5.com/weblogs/jason/archive/2009/09/08/irules-insight-http-event-order.aspx
John - smp_86112
That's what triggers the LB_FAILED event. Something simple like this should work:when LB_FAILED { HTTP::redirect "/maintenance.html" } - Jon_46029
The LB_FAILED event seems to be the best option, though I do not have a complete test environment... I don't think the HTTP::redirect flies cause there's no HTTP connection (yet) to redirect.
From the wiki: (though the sample code and the text following are in conflict regarding the sequence of the "LB::reselect" and "pool" statements.)when LB_FAILED { 07 pool my_Pool 08 LB::reselect 09 log "Selected server [LB::server] did not respond. Re-selecting node from myPool" 10}
