GianlucaP81_302's avatar
GianlucaP81_302
May 19, 2017
redirect to https non standard poprt
Hi, the requirement is:
http://virtualip:7777    have to be redirect to https://publicip:44444/abc
I was working with Proxypass adding a datagroup:
  • string: virtualip:7777
  • value:
it seems that the url redirect it works but is not working the port redirect 44444. The redirect is on port 443. Someone can help ?
  • Hi,
    Not sure what issue you have. Just attach below iRule to virtual:7777 VS and it should work:
           HTTP::redirect https://publicip:44444/abc
    Of course assuming that every request to should be redirected to static URI /abc.
    If it's not the case use:
           HTTP::redirect https://publicip:44444[HTTP::uri]
    Be aware that HTTP::redirect is always using 302 Found. If you need 301 then you have to use HTTP::respond, something like that:
    HTTP::respond 301 Location "Connection" "close"
    adding appropriate headers as needed
    Piotr
