Roman_80473's avatar
Roman_80473
Nov 29, 2011
Redirect to another URL from inside HTTP::REQUEST after timeout detected
Hi guys,
I have setup the timer using the 'after' command inside HTTP_REQUEST which I then cancel in HTTP_RESPONSE. I detect timeout and take node out of the mix. I then need to redirect request to another url, however both HTTP::redirect and HTTP::response give me the following errors:
- Illegal argument. Can't execute in the current context. (line 1) invoked from within "HTTP::redirect $theUrl"
- Illegal argument. Can't execute in the current context. (line 1) invoked from within "HTTP::respond 302 Location "$theUrl""
Is there a way around it?
Thank you, Roman
  • can you try this?
    log local0.debug "2. Redirecting to $theUrl"
    both redirect and respond give "Illegal argument. Can't execute in the current context. (line 1)", TCP::respond has no effect
    TCP::respond "HTTP/1.1 302 Found\r\nLocation: $theUrl\r\nConnection: close\r\nContent-Length: 0\r\n\r\n"
    this is mine.
    [root@ve1023:Active] config curl -I http://172.28.19.79
    HTTP/1.1 302 Found
    Connection: close
    Content-Length: 0
    Nov 30 11:47:19 local/tmm debug tmm[23027]: Rule myrule HTTP_REQUEST: F5 Host: 172.28.19.79, /, 80 ... Server: :
    Nov 30 11:47:19 local/tmm debug tmm[23027]: Rule myrule LB_SELECTED: In lb_selected, server is 200.200.200.101:80 ...
    Nov 30 11:47:19 local/tmm info tmm[23027]: Rule myrule HTTP_REQUEST: *** Timeout after 3 ms ***
    Nov 30 11:47:19 local/tmm debug tmm[23027]: Rule myrule HTTP_REQUEST: 1. Taking node 200.200.200.101:80 out of the mix ...
    Nov 30 11:47:19 local/tmm err tmm[23027]: 01010028:3: No members available for pool foo
    Nov 30 11:47:19 local/tmm debug tmm[23027]: Rule myrule HTTP_REQUEST: 2. Redirecting to
    Nov 30 11:47:19 local/ve1023 err mcpd[21973]: 01070809:3: iRule has marked pool member 200.200.200.101:80 down, no monitor to mark up.
    Nov 30 11:47:19 local/ve1023 notice mcpd[21973]: 01070638:5: Pool member 200.200.200.101:80 monitor status iRule down.
  • Hi Roman,
    I have been looking at your iRule. The first thing that I am noticing is that you are setting variables in the RULE_INIT event that are being reset in the CLIENT_ACCEPTED Event and then again in the HTTP_REQUEST Event.
    The RULE_INIT is triggered when an iRule is added or is modified.
    The CLIENT_ACCEPTED is triggered for each client when they connect to the Virtual Server hosting the iRule the first time.
    The HTTP_REQUEST for each individual request.
    So you are doing some work twice for nothing when you could just do them in the HTTP_REQUEST event (since you are resetting them for each individual request anyway).
    These are the ones I am referring to:
    set theUrl ""
    set retry 0
    set server_addr ""
    set server_port ""
    set host_name ""
    set host_uri ""
    set host_port ""
    set host_port_str ""
    set host_protocol ""
    set postBackUrl ""
    As far as your error, can reproduce the error, but I am wondering if the illegal argument error that you are getting is due to something missing.
    What does the logging statement show in your LTM Log:
    Does it appear to be the correct URL that it should be?
  • Hi nitass,
    Thanks for your reply. Yes, I've tried the "&", and LTM has choked on the syntax:
    Rule Smart_LB_Rule : 1. Taking node 10.2.178.121:8001 out of the mix ...
    TCL error: Smart_LB_Rule - invalid command name "host=10.2.178.121&" while executing "host=$server_addr&"
    Funny thing is that this scenario works fine inside LB_FAILED (when server is down), and I do get redirected to the controller url. The same goes for HTTP_RESPONSE when I detect http code > 500. I have a feeling it's the "after" command pecularities which prevent me from doing redirect.
    Thank you,
    Roman
    PS: You must have edited your post while I've been trying your suggestion :)
  • Yes, I've tried the "&", and LTM has choked on the syntax:sorry, have you tried TCP::respond i posted? it seems working in my lab unit.
    PS: You must have edited your post while I've been trying your suggestion :)yes, it seems devcentral does not like triangle bracket. so, i had to edit my post. :-)
  • Hi Michael,
    Thank you very much for looking into my messy rule. Yes, you're abs right, and I do need a lot of cleaning to do. I will as soon as I get it working, I promise.
    As far as the url, this is what I see in the logs (masking sensitive data):
    Rule Smart_LB_Rule : In lb_selected, server is server.ip.address:8001 ...
    Rule Smart_LB_Rule : *** Timeout after 15000 ms ***
    Rule Smart_LB_Rule : 1. Taking node server.ip.address:8001 out of the mix ...
    Rule Smart_LB_Rule : 2. Redirecting to http://domain_name.company_name.com/controller/?source=ltm&action=restart&host=server.ip.address&service=/bad/&port=8001&name=&cause=no_response_from_server_after_15000_ms&postBack=http://domain_name.company_name.com/bad/
    TCL error: Smart_LB_Rule - Illegal argument. Can't execute in the current context. (line 1) invoked from within "HTTP::redirect $theUrl "
    The url is valid, and if I put it in the browser, it works just fine. It also works (the HTTP::redirect $theUrl command) from inside both LB_FAILED and HTTP_RESPONSE events (as I've described to nitass). I have a sneaky suspicion it's the "after" timer that is giving me a trouble.
    Thank you,
    Roman
  • Hi nitass,
    Sorry, I didn't see TCP::respond in your post. I've tested my rule with it a dozen times, and it seems to be working fine! I'm pretty sure I've tried the TCP::respond beforehand, but I guess I didn't have the complete syntax
    Thank you very much for your help!
    Roman
  • The solution is there, but did anyone ever determine why the HTTP::redirect is being executed within the CLIENT_ACCEPTED context, as the error message states? Why isn't it being executed only within the HTTP_RESPONSE or HTTP_REQUEST contexts?
    What is it about using "after" and a timeout period that seems to cause the code to be run in the CLIENT_ACCEPTED context?
    I have a similar rule that uses an after that periodically triggers a similar error (only difference is that I'm trying to use HTTP::respond). I put the command in the HTTP_REQUEST context, yet it's being triggered in the CLIENT_ACCEPTED context.
  • not sure if i catch you correctly. anyway, i am also wondering what context after's script is running is.
    for example, when using HTTP::redirect instead of TCP::respond in the following example, i got context error.
    send response from BigIP if server does not respond within a specified amount of time
    https://devcentral.f5.com/wiki/iRules.after.ashx
    /var/log/ltm
    Aug 10 15:30:03 local/tmm info tmm[4860]: Rule myrule : Timeout 1000 milliseconds elapsed without server response. 1344583803
    Aug 10 15:30:03 local/tmm err tmm[4860]: 01220001:3: TCL error: myrule - Illegal argument. Can't execute in the current context. (line 1) invoked from within "HTTP::redirect "http://www.google.com/""
    i think i will open a case to verify unless someone here can give me a shot. :-)
