Aj_2549's avatar
Aj_2549
Aug 06, 2009
Redirect rewrite Help.
Under profile TAB I do see redirect reqrite enabled for one VIP matching all.IF someone bypass this rewrite for specific Ip what irule so we need to configure .
Ajay
  • hoolio's avatar
    hoolio
    Hi Ajay,
    You can determine whether rewrite redirects is enabled on a specific HTTP profile using PROFILE::http redirect_rewrite (Click here), but you cannot modify the configuration using this command. I think you would need to manually implement the rewriting of redirects using an iRule and then not do it for specific IP addresses. There is a Codeshare example from Deb which you could modify to do this:
    Rewrite HTTP Redirect Hostname
    http://devcentral.f5.com/wiki/default.aspx/iRules/RewriteHTTPRedirectHostname.html
    You'd want to change "myold.hostname.com mynew.hostname.com" to "http:// https://" and then add a check of the client IP address using IP::addr (Click here) or matchclass (Click here) in HTTP_RESPONSE:
      when HTTP_RESPONSE {
         Check if server response is a redirect and client IP is not 1.1.1.1
        if { [HTTP::header is_redirect] and not ([IP::addr [IP::client_addr] equals 1.1.1.1])} {
            Log original and updated values
           log local0. "Original Location header value: [HTTP::header value Location],\
              updated: [string map -nocase {http:// https://} [HTTP::header value Location]]"
            Do the update, replacing "http://" with "https://"
           HTTP::header replace Location [string map -nocase "http:// https://" [HTTP::header value Location]]
    Aaron
