Austin_Geraci_1
Mar 13, 2007Redirect Problem
I just want to do a basic redirection;
www.mydomain.com
www.mydomain.com/directory1/directory2
When I use the syntax below I get;
www.mydomain.com/www.mydomain.com/directory1/directory2
How Can I get rid of that initial uri??
Thanks!
if { [HTTP::uri] eq "/" } {
HTTP::redirect "www.mydomain.com/directory1/directory2/"
- hoolio
If you don't include the protocol in the redirect the browser assumes appends the new redirect value to the URI is just requested. If you add http:// or https:// to the redirect it should work fine:when HTTP_REQUEST { if { [HTTP::uri] eq "/" } { HTTP::redirect "http://www.mydomain.com/directory1/directory2/" } }
Aaron - Austin_Geraci_1
Great, I actually found some doc on this last night, i appreciate your quick response!
Are there any specific books on iRules? Or am I just going to find TCL books? Either way, can you point me to some recommended literature?? Or is DevCentral as good as it gets right now??
Thanks! - hoolio
That's good to hear.
There aren't any books on iRules. You can get more information on iRules from a few resources:
The iRule wiki on DC (Click here)
The LTM configuration guides on AskF5 (Click here)
The TCL manual for standard TCL commands/syntax (Click here)
And of course the posts in this forum, the codeshare, blogs and guides on DC.
Aaron
