Martin_Kaiser_1's avatar
Martin_Kaiser_1
May 18, 2011
Redirect http client to https on same non-default port
Hi guys,
I have a customer request of which I'm unsure whether it can be done at all or not:
I have a virtual https server on a BigIP running 10.2.0HF2. The virtual server is not running on port 443, but on non-default port 12345, balancing on a pool of development servers (plain http, SSL handling done by BigIP). Now, the customer requests a redirect from http to https in case the developers mistype http://some.site.net:12345 instead of https://some.site.net:12345
The problem is: you'll have to use an iRule event which is triggered very early during the transaction (e.g. CLIENT_CONNECTED or RULE_INIT), but I'm not sure how to make the iRule realize that there is a plain HTTP request following WITHOUT prior SSL handshake and then issue a SSL::DISABLE followed by an HTTP::REDIRECT...
Any ideas on that? Many thanks in advance!
Martin
