xiangyang_zhang's avatar
xiangyang_zhang
Apr 21, 2006
Read&Write problem
With the irule below, can read-write problem happen ?
rule tls_flag {
set tlsflg 0
if {[HTTP::method] equals "CONNECT"}{
set tlsflg 1
when HTTP_REQUEST_SEND {
if { $tlsreq equals 1 } {
HTTP::disable
Put it with an example
1. The instance 1, a HTTP request, invoke HTTP_REQUEST, so the tlsflg will be set as 0.
2. The instance 2, a HTTPS request, invokes HTTP_REQUEST, then tlsflg is set as 1.
3. Instance 1 going to invoke HTTP_REQUEST_SEND, at this point, what value is tlsflg, 0 or 1 ?
Thanks for any information !
  • Variables are shared within the same connection. If you want to use them across sessions, you'll have to reference them in the global namespace.
      set local_var "some value"
      set ::global_var "some other value"
      log local0. "The local value is $local_var"
      log local0. "The global value is $::global_var"
    So, the value in the HTTP_REQUeST_SEND event will be that of the associated HTTP_REQUEST event for that connection.
    Be careful about using lots of global variables as they remain resident in memory until the configuration is reloaded.
    -Joe
  • Many thanks, Joe ! Your answer is always helpful and precise !
    Just now I did the statistics for the hit of if-statement
    Under 600TPS and at the interval of 5 minutes, the hit number on
    set tlsflg 1
    is about 5% higher than on
    HTTP::disable
    Under lighter load, the numbers of hit are identical.
    It seems the local variable cannot keep persistent for one connection when load is higher.
