Fletcher_Cocquy's avatar
Fletcher_Cocquy
Feb 22, 2007
re-ip admin interface
The BigIP admin interface is on a network with nodes I want to loadbalance via one of the gig attached ports.
So I am looking to re-ip the admin interface (below)
eth0 Link encap:Ethernet HWaddr 00:E0:81:2F:4A:68
inet addr:18.88.88.80 Bcast:18.88.88.255 Mask:255.255.255.0
inet6 addr: fe80::2e0:81ff:fe2f:4a68/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:350617475 errors:0 dropped:0 overruns:0 frame:0
TX packets:298660491 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:785586255 (749.1 Mb) TX bytes:968007097 (923.1 Mb)
Interrupt:31 Base address:0xc400 Memory:fe9fd000-fe9fd038
I will re-ip eth0 to be 18.88.64.53 ? what is the best way?
Do I just update the files below (for persistency across reboots?)
Then
ifconfig eth0 18.88.64.53
To have it take immediate effect?
[root@irt-lb-03:Standby] config find /etc -type f -size -1000 -print | xargs egrep 18.88.88.80
/etc/sysconfig/network-scripts/ifcfg-admin:IPADDR=18.88.88.80
/etc/sysconfig/network-scripts/ifcfg-admin:SRCADDR=18.88.88.80
/etc/hosts:18.88.88.80 irt-lb-03.stanford.edu SAVE id - 18.88.88.80.irt-lb-03.stanford.edu
  • As an FYI, health monitors will use the path through the admin interface as a last resort, so I install management host routes for my ntp, snmp, radius, syslog, & ssh server destinations instead of a management default route to avoid this behavior.
