Re: IIS Based Application Load balancing Issue - F5
what's the " Source Address Translation " setting of the VS?
the default value is None.
simply setting it to Auto Map usually will solve the problem
  • shivam960's avatar
    shivam960
    Hi Zamroni,
    We will check this as well. In the meantime, could you please confirm which load balancing algorithm is recommended for an IIS Windows-based application?
    Currently, we are using the Round Robin algorithm, but all our packets are showing as abandoned.
    Thanks & Regards,
    Shivam
