Re: F5 Virtual appliance - VLAN Management
Thanks Kevin,
I have configured interfaces as you've suggested. And I can access the appliance using the Management IP address and Internal VLAN self IP address. However I don't have internet access from the F5 console.
The default route is pointing as 0.0.0.0/0 => 192.168.20.1 (InternalVLAN IP address).
Management (Host only) 192.168.10.0/24
External VLAN (1.1) - (NAT) 192.168.20.0/24
Can reach 192.168.20.1 successfully.
Internal VLAN (1.2) - (Host Only) 192.168.30.0/24 Cannot reach 192.168.30.1
I am sure I made a configuration mistake somewhere. As I don't internet access from F5, and none of the Host-only interfaces are reaching their gateway, .1
Can you correct?
