JG
Cumulonimbus
May 28, 2014Re-editing posted message: Issue with "Preformatted Code".
I have found that if I re-edit an already posted message, any change to the section in "Preformatted Code" will not take effect. Not sure if this is intended.
- Kevin_Davies_40
Nacreous
Its worse than that. If you have more than one preformatted code block you cannot edit your message again. It is effectively read only.
